Continuity (conductivity) and resistance are opposite sides of the same coin. Yes, you need some sort of "juice" to prove a circuit. That is provided by the battery in your multi-meter.
You use the ohm meter mode of your multi-meter to check for resistance (or LACK of resistance):
High resistance (big number) = open circuit. Low number (theoretically ZERO) = intact circuit.
