I'm thinking that the 277 is just an early small displacement 318 (poly that is). Does it have the same scalloped valve covers as the 318s up to 67? The initial design of the 318s was rear sump with the oil pump in the pan under the dist. so it would probably use the truck pan on a B or RB engine. Bryce
Every electronic device is manufactured with smoke stored deep inside...
only a true genius can find a way to set it free.
The most terrifying words in the English language are: "I'm from the government and I am here to help!"
