During heat soak, the fuel evaporates, and sometimes pushes out of the bowls into the motor, causing a flooding condition momentarily.
How would this happen? Would not the evaporating/boiling fuel simply vent out of the bowl vent tubes?
Unless it overloads the vents I watched as the secondary area on my carb got nice and moist with fuel after shutting it off once, as I listened to it boil
A wood spacer is going to be my next project.
If you ever find yourself in a fair fight, your tactics suck.
