The .92" torsion is rather soft, but will feel like [censored] with the KYB shock. It's like they feel stiff and harsh while not giving any handling improvement. How much are they each these days?
I can't agree with enough. Guy is totally right! I've driven KYB shocks with both soft and stiff springs. They're [censored]. I've found you can run a stiff spring and large sway bars if you spend coin on good shocks. The 5A has 300# torsion bars in the front, five leaf springs in the rear, a 1.25" bar in the front, and a .75" bar in the rear. Also 18" rims with very little sidewall. A very stout setup and it rode so bad I was about to toss 15" tires back on. Instead I pulled the Bilstein shocks off and used Viking 19-way adjustables. The car is as comfortable to drive as my Equinox with the knobs set one click above the recommended comfort settings. I cannot recommend these shocks enough. Expensive, but WORTH EVERY PENNY.
