Every time I had an engine that is pulling oil (minus putting it in the lifter valley), the way to stop it was to seal the engine up. Without air or blowby, oil can't be pulled into the vacuum pump. I had engines with huge vacuum leak that pulled 3 or 4 oz per dyno pull, at that point we stop and find the source of the leak.
Joe
Without Data, you’re just another guy with an opinion.
