Drop base air cleaner! I've been using a drop base air cleaner but I have a small 1/2" riser that sits on top of the carb and under the drop base bottom part of the air cleaner. Is it possible that the bottom of the air cleaner could be too close to the vent stacks???? I've only used the drop base style cleaner before so can someone recommend a good functional air cleaner assy?
