need to loose 4 rods/links:
passenger side:
manifold choke rod
choke pull off rod
driver side
high step cam push rod
Accelerator pump
Disconect gas line
10 screws on top... 8 are visible. two are inside the front airn horn
then will be able to remove the top section of body
You can make mounted on engine yet, and rest of parts will keep on car.
assemblying will need to remove metering rods, and mount them back once top plate is mounted. With everything in place, the Common metering rods link need to be loosen ( small screw on top and a cover. that will give you teh chance to partially loose that link.
also will need to remove the metering rods covers ( one small machined screw on each side and the cover )
hook the metering rods to the link, and push it untill get in on jets centered ( you can feel it, trying to push them down without problem ), and get the cover assemblied back.
