Originally Posted by TJP
Originally Posted by rickseeman
Since you are starting from a shell you might (for simplicity) get a self-contained ignition and ditch the ballast resistor and ECU. It would be cheaper too.
If your meaning aftermarket like MSD, My issue with them has always been parts availability when the unit cr-ps out or is suspected of doing so, especially when out of town. may have something to do with an experience I had years ago that's been hard to ignore due to the cost incurred. beer
Analog MSD 6AL's are way more available than the Chrysler stuff! Pick up one at a swap meet for less than $100 and keep it in the trunk if you're driving a lot. Personally I've never had one fail in over 30 years. Hook it to a Chrysler distributor and it works perfectly.
'63 Dodge 330
11.19 @ 121 mph
Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
10.01 @ 133mph with a 250 shot of nitrous an a splash of race gas. 1.36 60 ft. 3,700 lbs.
