Originally Posted by Cab_Burge
Is it leaking, seeping or weeping?
If leaking, drips or more, it probably needs a tear down, good cleaning and relacing the needles and seats. If it is seeping and or weeping you may be able to stop that by tightening the fuel bowl screws a little bit, not a bunch so you don't strip or break the bowl screws. Both of those conditions are caused by the fuel bowl gaskets shrinking with under hood heat and age twocents shruggy ITHS scope
Thanks.... looks like maybe floats or float is stuck... tried small hammer knocks.... but nope... looks like mostly from here
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
