We switched to beadlocks after fitting radials, using screws to locate the bead isn't recommended and after the tyre kept slipping on the rim we made the switch. Like you I couldn't see the point of a single beadlock. McFab are likely one of the companies you are thinking about but some style of wheels they are unable to convert so best to check, there is a good thread about this on Yellow Bullet. EDIT:They couldn't do my Convo pro's so I got some from Holeshot
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
