It is easy enough to find a quality or original electronic pickup assembly and cam, if not complete distributor. Clean it up and convert. Harness is available, then get a ECU. Keep the points as a back up. Having said that, my 70 still runs points as a weekend car and I have not messed with it since the tune up about 5 years ago. Used OEM original points and condenser.
