Well, got a look at the wiring I put in last year from Painless, and its all wired right and nice and neat, but the fans must be drawing a bit more than last year, and the Painless kit was pre-wired, and I smoked all the wires to the fan furthest away. Not to mention the water pump won't come on, so I think one relay is dead. This kit should have been enough to run everything. Worked all last year.
I looked up the fans I bought from Wizard Cooling, and they are rated at 21amps, but I think they pull more. The Painless kit does not say what size wiring or ratings its built to, but tain't working this year.
Going to have to re-wire everything with a Leash Pro 8 relay board I think....It least those are rated 70 amps, and I will wire everything with 10ga...for next year. I give up for this year because I also need treaded street tires and rims, its been raining every other day like crazy here, and I can't get caught with DOT slicks on it.
https://proshop.summitracing.com/parts/prf-30117https://leashelectronics.com/products/pro8-relay-module
