Yes that's it at the BACK left/driver's side of the gas tank. Just pop off that rubber cap and use a vacuum pump like above or an electric fuel pump. You may find a local auto parts cheap electric fuel pump or a Harbor Fright (pun) vacuum pump also like above?
