Redo the tune. A 3310 on a 383 is the correct carb. Don’t believe me and want to talk charts and theories, go run one back to back with the stock carb. You won’t want anything to do with something that small after you do. Easy thing to do back in the day was to put an avs from a 440 on your 383. Mine got good mpgs with a 3310.
