waveHi TX , Can you do Us a Running Test , and check Front and Rear WET Fuel Bowl , gas level settings too ? Please have a rag under the bowl screws , as you check Fuel Carb WET Level , Idling and running on the Vehicle . ALWAYS Different than DRY Setting from a Carb Rebuild Specs . drive bump post back , Ronnie
