All it takes is just one cold dark night, a little humid, and you and your "girl" have listened to the stereo a little too long, and now the cranking speed is a little slow, and you top things off by nearly flooding the engine. So there you are, the spark is weak..
Sounds exciting. I ran the big yellow Accel super coil w no ballast(hei module) & no problems & didn't know at the time that I needed one .
