Originally Posted by polyspheric
The easiest and cheapest plan is to duplicate somebody's successful project.
The odds of getting it right on your own the first, or 5th time, are not good. It's much more complicated than a N/A engine, minor tuning changes are worth 100 hp, or a big explosion.
Otherwise, I can suggest 10 or 15 books you can go through...
Exactly, starting on the weaker side saves parts, someone will always buy the used parts as you get stronger.
