Originally Posted by Stanton
Are these fed
a) each from a separate meter or
b) each fed separately from a single meter
c) one panel is fed from the other
One panel contains mostly 120v loads, Second panel has well pump, heat pump and furnace (90A breaker that goes to small sub panel).
