Originally Posted by Sniper
Does the sending unit have a good ground when it is installed?
Thanks for the reply.
The pump body is plastic but there are two ground terminals in the push in block, one for the pump (which works) and one for the gauge.
I am going to run a temporary ground tomorrow to the gauge ground from a good ground source, just to check.
[Linked Image]ttp://[/img][img][img]https://i.imgur.com/SQIxA0s.jpg[/img][/img]
