Didn't Mopar start stamping the 1968 , not before, blocks with the VIN and in some cases the sequence codes on the rear of the blocks on the driver side on the mating surface that the blocks bolted to and on SOME the 1968 blocks on the bottom of the passenger side blocks on the ear surfaces that the oil pans bolted onto that the 7/16 lower bolts to the tranny went through?
