Originally Posted by TJP
Originally Posted by Sniper
Free play is irrelevant.
What you really need to look at is pressure plate departure. I shoot for .060" with the pedal fully depressed. Free play ends up being what it ends up being. Now this does assume your entire clutch linkage setup is not all wore out and is in good condition. If it is not fix that first.
Free play can become relevant if there is none, not trying to be an a-- just clarifying beer
True, but if you have no freeplay at .060" departure your problem is something wrong in the linkage .
