Best mod for the 392 is a tune from a reputable professional, I've seen as much 30-50hp increases and they can also remove the torque management between shifts (ECU pulls timing when shifting to be easier on the trans), which helps even more than the power increase. They can e-mail you a tune but you'll need a Diablo to install it https://shop.ostdyno.com/shop/
