Hi A12, where are you located in NE Ohio?
I live in Kirtland and I need to cut the hole in my glass hood for the scoop.
This is a hood for our 70 Charger 6-pak.
If you could make a template or give me some measurements of the offset
from centerline and back edge so I don't bungle the opening, it would be greatly appreciated.
If you do a template, I could pick it up.
Thanks, Joe
