It is the wire.
It is a special wire that acts like a fuse if there is too much draw on it.
If you buy a generic fusable link from the parts store make sure to also buy one of these pakard 56 terminals.
so you can terminate it correctly.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
