So are you using a volt meter to test for voltage?
Where do you not have voltage at?
Have you pulled the bulkhead connector to take a look?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
