Re: Cal trac explanation please
[Re: 340Cuda]
#301491
04/30/09 10:22 AM
04/30/09 10:22 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Von, These are the instructions they gave me when I got mine several years ago:
Top Hole – Hardest Hit (start here)
Bottom Hole – Softer Hit, moves IC forward
More Pre-load, Softer Hit
Less Pre-load, air gap, harder hit
If car pulls to the right add a quarter turn of pre-load to the right bar and visa versa.
Set front shocks soft
Set rear shocks on #5, if car wants to porpoise go to 6 or 7 (harder).
If car spins, needs harder hit, go softer
Too much wheelstand…. Softer hit, restrict front travel
Good Luck, Bill
Thanks Bill! That is what I was looking for.
Gonna try using the top hole as Ive been in the bottom hole. I for sure dont have a high HP combination.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
