That’s what I thought you had.
1.6 rockers?
I guess you could pull off a couple intake springs and have them tested.
Personally, I’d like to see more open load....... especially since with the lifters you have, and the way you have them set up, there is no worry about bleed down.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
