Now most folks would have started welding, but that was not the best way to work with the metal k-member. Though it might seem over kill, I started with having the k-member heated up to nearly glowing and slowly let it cool for a full day. This removes any impurities left from the chem dip and helps strengthen the metal in the unit. This was done two more times during the week, making for stronger metal and having it ready to for welding. Tech from FFI made the brackets for reinforcing the k-member easier then than doing it myself and make for quick work, brackets and reinforcement work to be done correctly, it was then taken to Magnum Force Racing and one of their certified welders did all their magic to make this unit super strong and rigid. Clean and great welding can be seen where there were gaps and media blasting final prep before off to powder coating.
FEC15E31-8F96-42F3-A9A4-217CB9A072BF.jpeg186F3755-586B-427D-8230-FDE19515721C.jpeg120D41A7-12A8-411C-BF62-ADA666C8FCA1.jpeg7DF534A4-8CFF-4309-8FBA-ACBD80BD75A1.jpeg
