Since I wanted better handling and easier servicing, I did a lot of work checking into these suspension and used the best sources and tech that would have made this a better than stock driving. The weak part in these suspension is primarily the k-member. If you look, it is formed sheet metal that has some welds and engine mounts on it, nothing more. So strengtening it will require more than quick fix items. Welding is required and a clean surface is best, so off to a chem bath to remove any contaminants.
