Re: Changed oil, no pressure, now this!
[Re: J_BODY]
#2978273
10/25/21 03:48 PM
10/25/21 03:48 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Any idea why the diff lengths? Guess I got to assume some aftermarket race blocks use that???
Did you cut the oil filter open? There are three length shafts to accommodate the different pumps. The shortest shaft goes with a stock style pump. The middle length is used with the Milodon 21815 pump. The long shaft is used when you’re running the sandwich plate between the pump and the block.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
Entire Thread
gsmopar
10/16/21 05:31 PM
Kern Dog
10/16/21 05:34 PM
Jeremiah
10/16/21 05:36 PM
A727Tflite
10/16/21 06:08 PM
INTMD8
10/16/21 06:13 PM
gsmopar
10/16/21 06:34 PM
A727Tflite
10/16/21 07:54 PM
Moparteacher
10/16/21 10:02 PM
mopar dave
10/16/21 10:16 PM
gsmopar
10/16/21 10:39 PM
pittsburghracer
10/16/21 10:53 PM
Bad340fish
10/16/21 11:12 PM
lewtot184
10/16/21 11:48 PM
Tig
10/17/21 10:46 AM
moparacer
10/17/21 12:39 PM
A727Tflite
10/17/21 03:10 PM
Stanton
10/17/21 03:43 PM
Bad340fish
10/18/21 01:41 AM
Stanton
10/18/21 02:30 AM
A727Tflite
10/18/21 03:04 AM
gregsdart
10/20/21 06:59 PM
gsmopar
10/23/21 03:17 AM
J_BODY
10/17/21 09:15 PM
sr4440
10/17/21 09:42 PM
EvilB1Dart
10/23/21 04:23 AM
moparx
10/23/21 04:12 PM
gsmopar
10/23/21 05:53 PM
J_BODY
10/24/21 02:57 PM
pittsburghracer
10/24/21 08:39 PM
gsmopar
10/25/21 06:30 PM
fast68plymouth
10/25/21 07:48 PM
J_BODY
10/26/21 01:09 AM
JERICOGTX
10/26/21 11:29 AM
J_BODY
10/26/21 01:45 PM
gsmopar
10/26/21 01:27 PM
Cab_Burge
10/17/21 07:43 PM
