Re: Changed oil, no pressure, now this!
[Re: gsmopar]
#2975086
10/16/21 06:02 PM
10/16/21 06:02 PM
Posts: 610 Boise
Moparteacher
Boise
Looks like abnormal downward force on the gear, thus into the cover. Do you have a an old-school rubber hose on the distributor shaft to prevent intermediate gear (timing) movement? What does the intermediate shaft bushing top side look like? Check the to see if the shaft has slipped and walked down the gear.
I don't think it's garbage related. It looks assembly related of something has moved around. Do you have the correct intermediate shaft installed? Is it possible you have a longer Milodon shaft installed?
Wedge and Hemi using Milodon Oil Systems with a steel high volume oil pump or Milodon #21814 and dual line spacer: #21001, #21150, #21160. Overall length 8.562", 7" of shaft out the gear. -Steel Gear 21500 -Bronze Gear 21520
Wedge and Hemi using Milodon aluminum pump #21815. Use with Milodon Oil Systems #21175, #21185, #21190, #21195. Overall Length 8.187", 6 5/8" of shaft out the gear. -Steel Gear 21503 -Bronze Gear 21523
Wedge and Hemi using stock-style pan and tube pick-up. Also used with Milodon Oil Systems #21000, #21010, #21100, #21110 and systems using a stock, Keith Black or Milodon #21814 pump. Overall Length 7.875", 6 5/16" of shaft out the gear. -Steel Gear 21505 -Bronze Gear 21525
Entire Thread
gsmopar
10/16/21 05:31 PM
Kern Dog
10/16/21 05:34 PM
Jeremiah
10/16/21 05:36 PM
A727Tflite
10/16/21 06:08 PM
INTMD8
10/16/21 06:13 PM
gsmopar
10/16/21 06:34 PM
A727Tflite
10/16/21 07:54 PM
Moparteacher
10/16/21 10:02 PM
mopar dave
10/16/21 10:16 PM
gsmopar
10/16/21 10:39 PM
pittsburghracer
10/16/21 10:53 PM
Bad340fish
10/16/21 11:12 PM
lewtot184
10/16/21 11:48 PM
Tig
10/17/21 10:46 AM
moparacer
10/17/21 12:39 PM
A727Tflite
10/17/21 03:10 PM
Stanton
10/17/21 03:43 PM
Bad340fish
10/18/21 01:41 AM
Stanton
10/18/21 02:30 AM
A727Tflite
10/18/21 03:04 AM
gregsdart
10/20/21 06:59 PM
gsmopar
10/23/21 03:17 AM
J_BODY
10/17/21 09:15 PM
sr4440
10/17/21 09:42 PM
EvilB1Dart
10/23/21 04:23 AM
moparx
10/23/21 04:12 PM
gsmopar
10/23/21 05:53 PM
J_BODY
10/24/21 02:57 PM
pittsburghracer
10/24/21 08:39 PM
gsmopar
10/25/21 06:30 PM
fast68plymouth
10/25/21 07:48 PM
J_BODY
10/26/21 01:09 AM
JERICOGTX
10/26/21 11:29 AM
J_BODY
10/26/21 01:45 PM
gsmopar
10/26/21 01:27 PM
Cab_Burge
10/17/21 07:43 PM
