Okay, so missed it by a year, but finally got my junk to Speed Week 2021! Had a good showing with a 187mph at the 2 1/4 on the short course right out of the trailer, which cleared me for the long course! Stayed on yhe short course for a couple more passes to work out some things, then moved over to the long courses. Lexan windshield caved in a little on a 217mph run, but we fixed that. Made a few mods and went 230.973mph exit speed at the 5 mile after averaging 229+ for mile 5. Stayed in the throttle to the 6 mile and burned a piston, so done for this year. Tires grew considerably which threw final calculated ratio off quite a bit. Also had inlet turbulence and fuel distribution issues that I must address. We will be back next year, class correct and ready to break the record if conditions permit!
217mph run, winshield caves at 53:37, uneventful-
https://youtu.be/QbIa7B70Rak
230.973mph run, other GoPro didn't capture.
https://youtu.be/IFnDxQg_iic
img_2_1629220322101.jpgimg_1_1629220308180.jpgSpeed Week Bonneville 8.21.21 6 resize.jpg
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
