Ive typed it out way to many times on here to do it again but yes it does work. I bought a motorhome that sat for five years and it fixed that carb without touching it. If you aren’t in a big hurry it will work on its own. If you need it tomorrow take the carb apart as nothing works right now without your labor.
Not in a hurry at all. So the seafoam mixed in the gas and sitting in the carb with dissolve the gum? And I guess break it down?
