What pulley are you using with the ATI damper and your low mount alternator setup..... Is that extra bracket needed to help stabilize the alternator
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
