Looks similar to the Ecp. But looks closer to a stock radiator. I use it with a shroud, 6 blade 18 inch flex fan, high volume mancini water pump, 160 Milodon stat and vacuum advance never see more than 180ish- maybe 185 idling or cruising. Without vacuum advance it got up to 200-210 at 70 mph 3500rpm.
