The hot start issue is most likely caused by today’s gas. It has a lower boiling point than the gas back in the day. It’s formulated got fuel injection. Can’t boil when under pressure. Had the same problem with my Super Bee until I put EFI in it. It would stall setting at the light due to the fuel boiling over in the og bowels and flood the engine.
