If you decide to go external oiling, here's what I use. I don't see why it would be a problem using it in an A body. Maybe just route the line differently. It's a Milodon pump w/ a stock cast iron cover. I like these b/c the pickup is in the pump, higher up, and not on the cover. The pan is from 440 source. The way the line is, it goes b/t the engine and K frame...no need to disconnect it to remove the engine from the car. A single line setup like that is exactly what I was thinking if I was to go external. Is that a kit from Milodon? or just the pump? Also, swinging or fixed pickup? I have done research on here of others saying they lose prime if the car sits, but saw you never had that issue....that still the case? Not a kit, just the pump itself from Milodon. The cover is a factory style cover off of a Melling pump. Just some normal -12 AN fittings and hose. The pickup is a static/fixed style from Milodon. The pan from 440 source doesn't have the hole in it for the pickup...just got a holesaw from the hardware store. Think it's 1-1/8" diameter. Zero problems w/ it losing prime. I have 2 cars with single line external systems. The other car has a Melling pump w/ a Milodon cover. Both cars have the lines immediately turning down and back to the pan. No need for the loop upwards. Dual line systems may be different in that respect.
