Originally Posted by Pockets
Ok, so if that were the case, no oil gallery, would the hi pressure pin oiling of the 861 lifter not receive oil either?
Correct. No pressure means no pressure. The 861 lifters will just have splash oiling if the gallery isn't drilled so no pressure for the pin and no pressure for the pushrod.
