Their vendor must have messed up the dimensions on a bunch of housings. I'm sure that if Brandon was told about it he will contact his vendor and get the bolt holes put back in the correct spot. There isn't any good reason for the vendor to drill the holes in the wrong spot. It doesn't save any money or anything, still need to drill and tap two holes.
