Thanks to all of you who commented. That is one of the reasons I like this site.
It's all about perspective.
I was amazed at the work put in for the probable return, but I didn't think about the heat treated pillars being welded and other stuff not up to spec.
He does have a slide puller I like. It spot welds the tip to the car, he yanks it, and then twists it to break the puller loose. Not great for hard dents but he uses it pop low spots up quickly.
