Hey Jim...
The problem with my existing K-Member is that it has a bend in the middle.
Not too bad, but according to my mechanic, bad enough to affect my tire wear over time.
I tried to get the front end aligned, and the mechanic said that he couldn't do much with it.
It appears that the previous owner ran over a water inspection lead pipe and then to make matters worse, slammed it in reverse and backed over the same pipe.
The mechanic said that I could do some tweaking to the other parts of the suspension and that might help.
I have everything else in the front-end removed and being updated at the moment.
So I figured this might be a good time to swap out the K-member, since it is only holding up the engine.
Good suggestions, but I'd like to see if I can do a replacement first.
Thanks!
Tim...
