If you want to be able to roll the car around just make up some caster that bolt to the bumper braket holes.Everthing is on the motor when done this way you get better fits and no scratches.Just did the same way to 65 B Body with a big block try it sometime.I think it's alot easier than from the top beside that i always did like the bottom""""""""""""""""""
