I got box of miscellaneous bends. At first i was trying to plan exactly how i wanted the pipes, then I decided to just start cutting and welding and see what happens. So far it's been a lot easier than I expected. I can up with an idea for how to located the collectors wherer I want them. I'll take pics of that and let you know how it works out. Equal length isn't too critical to me, I just want them to fit and function. I think I might be able to install and remove the driver's side by removing the steering shaft. THe passenger side is going to have to be two piece or R&R with the engine out.
