Re: Bleeding Brakes, without a helper
[Re: mopar97]
#2778544
05/26/20 10:29 PM
05/26/20 10:29 PM
Posts: 3,685 South San Francisco, Ca
70sixpkrt
Several things that have worked for me. Gravity bleed does work. Nut unless you want a mess to clean up later, slip a hose over the nipple and into a bottle. Use a metal oil can to fill the lines with fluid from the bleeder end. You can also use an old brake fluid bottle 1/2 full with a hose. Loosen the bleeder screw on the wheel in question, slide the hose over the nipple and insert into the fluid. Pump the brake pedal 10-12 times. This way you are pulling fluid from 1 end and pushing from the other. Do each wheel and then check your pedal. Make certain the bottle has fluid in it or you will be pulling air into the system. In every case the master cylinder was hardest to bleed. If I can I will bench bleed it. By doing this, aren't you pushing old fluid into new fluid? Mixing the fluid?
Entire Thread
QuickDodge
05/26/20 12:02 PM
NachoRT74
05/26/20 12:05 PM
dOc …
05/26/20 12:14 PM
jlatessa
05/26/20 12:49 PM
dOc …
05/26/20 12:59 PM
NachoRT74
05/26/20 03:07 PM
RapidRobert
05/26/20 03:17 PM
moparx
05/26/20 04:05 PM
John_Kunkel
05/26/20 06:39 PM
fourgearsavoy
05/26/20 01:26 PM
mopar97
05/26/20 01:41 PM
justinp61
05/26/20 12:08 PM
mopar97
05/26/20 01:20 PM
NachoRT74
05/26/20 03:16 PM
70sixpkrt
05/27/20 02:29 AM
Mr T2U
05/27/20 10:47 AM
05/27/20 12:48 PM
fourgearsavoy
05/27/20 09:39 PM
Guitar Jones
05/27/20 09:46 PM
fourgearsavoy
05/27/20 10:13 PM
5thAve
05/27/20 10:29 PM
dOc …
05/28/20 12:39 AM
Guitar Jones
05/28/20 01:37 AM
Mr PotatoHead
05/28/20 01:44 AM
kentj340
05/28/20 04:07 AM
Guitar Jones
05/28/20 08:59 AM
Mr T2U
05/27/20 10:37 PM
mopar97
05/28/20 04:23 AM
AndyF
05/26/20 07:32 PM
mopar97
05/26/20 08:00 PM
AndyF
05/26/20 08:40 PM
None2Slow
05/26/20 11:30 PM
BDW
05/26/20 11:36 PM
Guitar Jones
05/27/20 12:34 AM
Cab_Burge
05/27/20 01:34 AM
Mr PotatoHead
05/28/20 01:42 AM
mopar97
05/26/20 08:06 PM
5thAve
05/27/20 10:48 PM
Grizzly
05/28/20 05:05 AM
Grizzly
05/28/20 05:10 AM
Cab_Burge
05/28/20 06:14 AM
Grizzly
05/28/20 06:29 AM
Cab_Burge
05/28/20 04:39 PM
fourgearsavoy
05/28/20 07:16 PM
Grizzly
05/29/20 02:30 AM
NachoRT74
05/29/20 10:54 AM
Mr T2U
05/29/20 10:54 AM
NachoRT74
05/29/20 11:01 AM
Grizzly
05/29/20 12:25 PM
fourgearsavoy
05/29/20 12:37 PM
NachoRT74
05/28/20 03:07 PM
