Originally Posted by not_a_charger
Originally Posted by hemirdrnnr
Check your policy mine has a clause if I want to buy it back, she might try to sue you for being in her way. Glad you and your family are OK.
What does the "clause" in your policy say? I've never seen a policy that contains language to this effect.
Typically, this is not addressed specifically within a policy. If you own the car outright and want to keep it, you can keep it, and your insurer reduces the settlement amount by the projected salvage value amount. If you do not own the car outright, it is up to the leinholder whether or not you can keep the car, since they are actually the titled owner. They usually don't allow it. Not always, but usually.
Check the bottom right corner.
