Originally Posted by dart4forte
I believe the Map Sensor in internal to the throttle body
In that case you'll likely need to remove a fair portion of the divider between the two sides of the carb pad
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
