I would definitely be out of luck at that company.
Many years ago at either the GM or Ford plant in Atlanta (not sure which as I had friends that worked at the GM plant & FIL worked at the Ford plant for a while), they would not allow an employee to park a non-GM or Ford vehicle in the lot.
Tim
A friend of mine works at the Ford truck plant here in Louisville and said non Ford vehicles have to park in a lot farther away. He said other brands parked at the plant have also been known to get keyed.
