Thank's Dwayne & I'll check with Summit here to see if they have an in tank pump that'll work with this tank & isn't difficult to install. I wonder if the in tank pump has its own filter or if I can use the existing filter. If the in tank pump is a difficult install, do you think the Mallory or Holley street geroter pump down just in front of the tank would work?
