Do you have the MSD red wire hooked up properly? You need to attach it so it is hot both in "start" and "run". Sounds like you may only have the "start" wire hooked up.
If you hooked up your MSD according to the instructions it doesn't mention this. It has drove many a mopar guy crazy. DAMHIK
