Under the assumption your gauge is accurate
Cooling system is full , no air pockets
First you have to see if you adequate coolant flow thru the radiator at operating temperature
Leave the radiator cap loose , not pressurized , while bringing the car up to operating temperature at idle in park
Remove the cap
Above 180 you should see a nice steady flow of coolant across the top of the radiator
If you don’t - Thermostat not opening , water pump issue , collapsed radiator hose
Second , if you have adequate flow like described above
Radiator , as in it’s plugged or not enough capacity to cool properly
